Help me finish my system : )
Hey there. I need some help picking up a power supply for the system i'm building atm. Since in my country i'm limited at choice, i can pick between those two - Corsair CMPSU-750TXEU and Cooler Master Silent Pro M700. The Cooler Master one is like ~25$ cheaper. I'm not gonna use SLI or Crossfire in the nearest future, but i will overclock both the CPU and the GPU and i would like to get most out of them. So which one should i pick ? Here's the rest of the system:
ASRock P67 Extreme4
Intel Core i5-2500K
Noctua NH-D14
G.Skill Ripjaws-X F3-12800CL6D-4GBXH
Palit nVidia GeForce GTX570
Samsung Spinpoint F3 HD103SJ 1TB
Cooler Master HAF 922
5 answers Last reply
More about help finish system
  1. If those are your only two choices, Corsair.
  2. My vote goes to TX750 as well.
  3. Make it Corsair 3, CM 0
  4. Go with corsair ax850. gold certified psu. Very stable for OC'd 2500k + if you're gonna upgrade in the future for 2 gtx580, it will handle it.
  5. Go for the Corsair and btw, i`ve been reading arround the forums that the gtx570 blows up when overclocked, you should be careful overclocking it : /
Power Supplies Cooler Master Components
