This not really a noob question, it is actually pretty complex. I dont have an exact answer for you, hopefully there is someone on here that has a more complete understanding of hdds than me.
Every track on the HDD holds the same amount of info. So the smaller inside tracks are more dense than the larger outside tracks. Because the info on the inside is closer together it gets moved under the head faster and read faster. As the seek head moves to the outside of the disk the data is less dense and further apart so the performance is lower.
Generally because the inner tracks are closer to the center the seek head has to move less so seek times are lower.
However because the outside edge of the disk spins faster than the inside the info on the outer edges are spun under the head faster so often times hdd benchmarks show the outer edge as having a faster read write.
Here the seek arm has to move the most to read the data at the outside edge so the seek times are normally higher.
My guess is the lower perfomance is due to the increased seek time of the head moving more as it gets closer to the outside edge of the disk.
