Closed Solved
Power supply for AMD Phenom II X6 based system
Hello, I'd like to know what POWER SUPPLY you would recommend for an AMD Phenom II X6 based system
- Specs:
- ECS A890GXM-A(2.0) AM3 AMD 890GX SATA 6Gb/s HDMI ATX AMD Motherboard
- AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz Socket AM3 125W Six-Core
- G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
- Western Digital Caviar Black WD5002AALX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive
- DVD-RW Drive
- SB Audigy2 Sound Card
- ATi Radeon HD 3870
Thanks in advance!
10 answers Last reply Best Answer
More about power supply phenom based system
  1. Best answer
    here 39$ after rebate a fine 600 watt ps with a 80+ rating
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817815009
    and heres the review if u need it, quite good points :D
    http://www.hardwareheaven.com/reviews/957/pg6/xigmatek-nrp-pc602-600w-psu-review-conclusion.html
    cheers
  2. Whats your budget look like?
    Anything really 450 watts or better from a good company like Antec, Corsair, Seasonic will work fine for your system. I recommend getting at least a 550 watt unit for future upgrades of the video card.
  3. Thanks to both of you. Along with the parts mentioned above I bought this Power Supply:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817152028
    But then I realized that it might not have enough juice for my system. What do you guys think about that power supply?
    If I need to I will return it and get a PSU with more wattage.
    Thanks again.
  4. Raidmax is absolute crap why would you pick that?
    Pretty blue light :lol: :lol: :lol:
    If you saw my current case, you'd realize you assumed wrong. I could care less for led lights LOL.
    God, I love noobs
    I " assumed " nothing, I made a funny based on saaiello's question and the lighted fan on the psu, couldn't care less about your actual reason for the purchase.
    Welcome to the Forum
  8. I purchased it because of the reviews and price. But then I started to doubt wether the PSU had enough power. I was trying to stay under $50 for the PSU but that seems like a mere fantasy for a good quality 80+ PSU
  9. Best answer selected by BouRne1785.
  10. This topic has been closed by Maziar
Power Supplies AMD Phenom Components Product
