Need help! cheap build for starcraft 2
Last response: in Systems
Approximate Purchase Date: on black friday
Budget Range: $700
System Usage from Most to Least Important: For starcraft 2.
Parts Not Required:monitor.
Preferred Website(s) for Parts: newegg.com and tigerdirect.com
Country of Origin: US, ca
Parts Preferences: i dont know much about computer parts so i will leave this part to you.
Overclocking: maybe. << whats this?
SLI or Crossfire: Not sure about this
Monitor Resolution: 1920x1080, 1920x1200
Additional Comments: i hope you guys would help me with this. thanks in advance
More about : cheap build starcraft
SC2 doesn't use more than 2 cores so I went with a triple (theres a chance this can unlock to a quad) rather than a full fledged quad to get under budget before rebates and save more after.
$669.91 --> $604.91 AR
10% off w/ promo code nov68, ends 11/22 (For the PSU if you buy it today!)
Related ressources
You should really try to buy your monitor in store so you can check it out first. A lot of the time monitors will have great looking specs but are very disappointing when they arrive at your home.
chinitams said:
ok ok, Question: Why did you suggest amd? is it because of the budget or it fits well with my gaming requirements?
Both. I'm sure you wouldn't be able to tell the difference between these CPUs and an i7 in gaming.
AMD gets you the best bang for your buck. :D
Ask the community
