I recently put together the system below, and following Tom's guide on putting together a computer, my next steps are to test the stability of the machine and benchmark it. I downloaded the SpeedFan and ran the Prime95 Blend test. I was afraid to run it for long as the temp went up from 20something to 68 celsius (the little icon by the temp turned into a flame which scared me off continuing). So....how hot is too hot? I only have the stock heat sink with OCZ Freeze thermal compound. I want to test the system, not damage it!! I have not done anything to OC (at most, I might set the mobo to auto OC once I read up on that and know everything is stable).
Second, I tried my damnedest to get Futuremark 3D Vantage to work, but it won't post my results after the test is over, so I can't see how my system stacks up! I've searched their posts, but anything relevent (all posts relating to not posting results) date back to early this year or older, and say they've fixed the problem with Windows 7. Specs for the program only list Vista as the OS. I've emailed them, but haven't gotten any response. I won't pay for a full-version of a product that doesn't work as freeware and has such poor documentation. A lot of people seem to think it's great, though...am I doing something wrong?? I also created a login at Futuremark because someone's post asked the user if they were logged in when they took the test. Oh, and i also tried their online benchmarking test, but that hangs up or doesn't work in both Firefox and IE7.
Case:Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case
Mobo: ASUS M4A87TD/USB3 AM3 AMD 870 SATA 6Gb/s USB 3.0 AMD Motherboard
CPU:AMD Phenom II X4 965 Black Edition
PSU: SeaSonic S12II 520 Bronze 520W
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model
HDD: OCZ Vertex 2 OCZSSD3-2VTX90G 3.5" 90GB SATA II MLC Internal Solid State Drive (SSD)
Video: NVidea GeForce 9800 GT card
OS: Windows 7
(installed mobo drivers from CD, latest video drivers and all the windows updates)
OS: Windows 7
