Hi.
I use a XFX PVT95GZAFG GeForce 9500 GT 1GB 128-bit GDDR2 PCI Express 2.0 x16 Video Card, the motherboard is GIGABYTE GA-P55-USB3 with i5 750 and two G.SKILL Ripjaws Series 4GB DDR3. OS is Windows XP *32. This mobo worked fine in the past 1 month. But when I returned from a short journey and tried to turn the computer on, it just didn't work. The sym is: the motherboard and windows's graphical login interfaces is crappy, look like that the driver of the video card was not installed. If I login in a normal mode, the computer just does nothing but shows black screen or restart. If in a safe mode, I can login and I saw that in systems>hardware>graphic device, there is a big yellow question mark. I installed the latest driver and then the whole OS: nothing improved.
Interestingly, sometimes I can login successfully in normal modes like nothing has ever happen. However, when I tried to login again, it just fails again.
And btw, there are four phase LED on the motherboard, they are green, green, orange and red in series. Does anyone knows what that means?
Any suggestion is appreciated.
