What Next?? Help
Hi To All
Here is my system spec
Asus P5Q-E
Wolfdale E8400 @ 3.6 GHz
4GB ballistics DDR2 @ 900 HMz
ATI Sapphire 4870 @ 810/1000 MHz
The Hard Drive is not so good but iv already ordered a solid state
These are all running at good cool temps, and i was wondering what would be the best thing to do next to get the best GAMING performance increase.
Thanks all
8 answers Last reply
More about what next help
  1. Hello
    What resolution do you play at ? and what's your PSU ?
  2. 750w psu and i play at 1920*1080
  3. HD 6870 is a good choice and will give you almost double the performance of your 4870.
  4. So go with a GPU update rather than a MoBo budle such as i5
  5. For gaming yes,because your CPU is fine for handling all games.
  6. Are you running a Core Duo or Quad-Core processor? Have you set the proper BIOS settings to unlock the available CPU cores? Sometimes, the BIOS settings for the older LGA775 socket are not as intuitive as the newer BIOS versions. I had to carefully set my system voltage to unlock the dual core in my Intel Core Duo CPU when I built my PC a few years back.
    Its a Wolfdale E8400 dual core...
  8. If you were going to update your CPU and Board, I'd wait. Like Maziar, upgrade your GPU first. Then wait for SB and BD to come out next year. Those'll be some great prospects to look at. OC your E8400 a bit and you should reduce bottlenecking. Also the SB is supposed to be "mid-range price" oriented says intel. So it shouldn't be TOO expensive.
    SB: http://www.anandtech.com/show/3871/the-sandy-bridge-preview-three-wins-in-a-row
Homebuilt Systems
