AMD/Intel Build Help
Last response: in CPUs
Hello forums! I'm planning to build a desktop AMD or Intel. Would be nice if the rig lasted for 3 years+ at least with futurability. Budget is 500-650 I could be flexible but the closer to 700 is pushing it. I'll be mostly playing Starcraft II and WoW (as close to Ultra or at Ultra settings as possible with good frame rate). I endured framerates on a laptop that would make everyone cringe and grind their teeth. It was really bad. Ironically when I stopped playing Starcraft II and WoW my laptop decided to completely die so now is the opportunity to get a desktop. I do have a 1440x900 eMachines monitor still in the box in my closet, no OS. That's about it. A year ago I considered Cyberpower and iBuyPower even though they're the same company but they have horrible reps. I am looking at Avadirect and will most likely buy off there. I'm open to different builds. Help me out! Thanks.
More about : amd intel build
Here's what I put together after messing with the bargain and budget builds from the guide. I do plan on upgrading the CPU later on with an X4 955 BE and a better GPU when I need it. Would these all work if I were to do that later on? Note that this is mainly for Starcraft and World of Warcraft (Ultra settings if possible) on 1440x900 which I will plan to upgrade later on as well. I had to flex the budget but I'm pretty satisfied on the compromise if it's an okay build.
AMD Athlon II X3 450 Rana 3.2GHz Socket AM3 95W Triple-Core Desktop Processor ADX450WFGMBOX
Sunbeam CR-CCTF 120 mm Core-Contact Freezer CPU Cooler, free TX-2 Thermal Paste Included Inside
ASRock 870 EXTREME3 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRM
SAPPHIRE 100283FLEX Radeon HD 5770 FleX 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
LITE-ON 24X DVD Writer Black SATA Model iHAS424-98 LightScribe Support
COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
Also should I stay with the OEM heatsink and fan or go ahead with the Sunbeam?
Related ressources
- Amd/intel reseller status?..... - Forum
- AMD/Intel version comparison - Forum
- RANT regarding Double Standards * AMD/Intel * - Forum
- AMD/INTEL Build : Need Review - Forum
- New build , gaming focus but CS5 as well, torn between AMD/Intel - Forum
Wow scales very well and runs even on my 2.1ghz laptop, SC2 needs a bit more imo. The triple core should do fine i think.
I would grap a hyper 212+ before I grabbed the sunbeam and only if you plan on overclocking. If you are going to stay at stock speeds then the stock cooler will be fine but a tad hotter than a good aftermarket cooler.
I don't plan on overclocking on this CPU. Whenever I upgrade to an X4 955 I'll think about it but there's no real need. I don't mind playing Starcraft 2 on low settings seeing as we've all had to play the previous Starcraft for years and years with it's graphics. As for WoW it would be highly preferred if I could play on Ultra if not as high as the rig will let me without sacrificing frames. I've had to play with disgusting frame rate on my laptop.
Actually the Coolermaster would be better overall. I just kind of went with the guide. Should I stay with a 5770 with an X3 or an X4 with a 5450? I'm not sure which would be better for futurability in terms of gaming. I could see either way but I would like some advice on it.
get rid of the cpu cooler, find someone in college for the OS as they can get it much cheaper and get this gpu instead http://www.newegg.com/Product/Product.aspx?Item=N82E168...
it is much better and only a little more
Still wondering if I should sacrifice GPU for more CPU power seeing as WoW is more CPU intensive than it is GPU. I believe the 5770 was already overkill for the requirements, but I will consider it.
Anyone else have some ideas? X3 with a 5770 (or GTX 460 Fermi) or X4 955 BE with a 5450. I'm open to other suggestions though. To sacrifice one for the other and possibly upgrade the latter in the future. I'm also trying to keep in mind BD might affect the prices on these, but I may have it all done before they even have a date for that.
Best solution
AMD Athlon II X3 445
ASUS M4A87TD EVO + ASUS EAH6850
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
ASUS Black 24X DVD
SeaSonic S12II 520 Bronze
$591.93
http://www.tomshardware.co.uk/forum/274745-13-step-step...
http://www.youtube.com/watch?v=1y8T8QAsDZs
ASUS Black 24X DVD
$591.93
XKageOokamiX said:
Still wondering if I should sacrifice GPU for more CPU power seeing as WoW is more CPU intensive than it is GPU. I believe the 5770 was already overkill for the requirements, but I will consider it.Anyone else have some ideas? X3 with a 5770 (or GTX 460 Fermi) or X4 955 BE with a 5450. I'm open to other suggestions though. To sacrifice one for the other and possibly upgrade the latter in the future. I'm also trying to keep in mind BD might affect the prices on these, but I may have it all done before they even have a date for that.
Just to give some sort of performance idea. I have a X3 445 and a 6850 playing wow @ 1080p and get 45-60fps on Ultra. Dal is the exception, when crowded I will dip to 25-30ish.
Are there any benchs that compare the 5770 and the 6850 on the same processor? I'm going to be playing at 1440x900 but I just want to see if the changes are substantial enough. I can always get a better monitor down the road and would it be better in terms of future proofing to get an X4 955 and a lower GPU than the latter?
XKageOokamiX said:
Are there any benchs that compare the 5770 and the 6850 on the same processor? I'm going to be playing at 1440x900 but I just want to see if the changes are substantial enough. I can always get a better monitor down the road and would it be better in terms of future proofing to get an X4 955 and a lower GPU than the latter?GPUs http://www.tomshardware.com/reviews/world-of-warcraft-c...
CPUs http://www.tomshardware.com/reviews/world-of-warcraft-c...
Well here's what I plan to build. I changed it and decided I'll buy the GPU later on so now I can fit the X4 955 in my budget I'll be getting a 6850 in the future which is why nothing is listed for GPU at the moment. If this winds up being a non-gaming computer I'm still going to be doing a lot of multi-tasking and as of right now I do more of that than gaming so holding off on the 6850 I'm okay with. Everything look good? I know there was some timing issues with a few of the G Skill Ripjaw series, but other than that am I good to go? I'm not going to be overclocking.
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor
OCZ Fatal1ty OCZ550FTY 550W ATX12V v2.2 / EPS12V SLI Ready 80 PLUS Certified Modular Active PFC Power Supply
LG DVD±RW SuperMulti Drive Black SATA Model GH22NS50B - OEM
motherboard
cpu
total = 335
your processor and motherboard total 230
you could drop your total proce by about 80 if you will listen to me and find a college kid cause i could buy you windows 7 for 20 bucks from my university. So now your total for the i5 2500k would be about 255 about where you are with the inferior phenom but is it to much work to save about 80 dollars?
cpu
total = 335
As for PSUs isn't it kind of hit and miss? I've been going over a lot of the Tier 1 and 2 PSUs and there's a lot of mixed reviews (though mostly positive of course). As first time builder I have this image of my PSU frying or blowing up in the case. Not being pessimistic just reviewing the scenarios in my head if I ever wind up with a bad one. CB I'm consdering the Sandy Bridges build, I dropped the OS and I'll pick it up cheap from someone
. Related ressources:
- Forumcould use some help on an AMD/Intel desicion
- ForumConfusion about motherboard and/or AMD/Intel machine ?
- ForumAMD/Intel and other thoughts
- ForumThe Myths about AMD/Intel *Fanboi's Should Read*
- ForumAMD/INTEL Video Encoding Tight Budget
- ForumThe AMD/Intel battle heats up....
- ForumAmd-Intel
- ForumAMD/Intel and Nvidia/ATI
- ForumCores/Hyperthreaded AMD/Intel
- ForumFirst time build , help please.
- ForumPSU Help
- ForumLooking for PCI-e x16 Riser Card for an intel style server
- Forum[Solved] Advise on Build
- ForumUpgrade intel t5200
- ForumOnly 3 cores are activated? Amd phenom X4 955
- More resources
