PSU died, replaced it but no viedeo. Need help
Last response: in Components
- My PSU Died! I need some help with a $1000 build with consideration to parts salvaging. - Forum
- Game Drive Died - Need Replacement Help - 840 Pro, 840 EVO, or Vector (250gb/256gb Size) - Forum
- GTX 750 TI SC not working after I replaced my PSU, and need help? - Forum
- PSU died, need a replacement any suggestions? - Forum
- PSU died, need help - Forum
- PSU died need a replacement Forum
- psu died, replaced and no post, Any ideas before I start buying parts? Forum
- Video Card Died Need Help for choosing replacement Forum
- PSU Died, Replaced with Old One, but having issues with games. Forum
- My pc just died..needs replacement!!help!!! Forum
- P5K Deluxe MB Died! Need Replacement. Help! Forum
- Solvedhard drive died need help getting new one Forum
- SolvedMy Gateway DX4320-17 Motherboard just died and need a replacement. Any suggestions? Forum
- SolvedGTX 680 Suddenly died for a sec and has been wonky since then. Cannot game at all. Help needed. Forum
- SolvedNeed some help choosing replacment PSU Forum
- SolvedMy pc died need help for problems. Forum
- SolvedNo display after replacing PSU. Need help! Forum
- Solvedi3 mobo died, need suggestions for a cheap replacement Sandy Bridge board... Forum
- SolvedNeed help finding a replacement PSU!! Forum
- SolvedNEED HELP! Will This PSU match this build? (replacing Xtreme Gear) Forum
- More resources
Read discussions in other Components categories
one night and returned to find no power on it. I pulled the PSU and tried it in an old machine I have and determined it was shot. I bought a CX430 PSU and installed it (I believe correctly) but now it is still not working correctly. I get power to all of the fans and can hear things start up but it doesn't POST and I get no feedback from the monitor.The old PSU was 350W so I think there should be enough power. I have tried another monitor but still no luck. I looked at the capacitors on the motherboard as well as the motherborad itself and there is no visible damage. I took it to a local shop and they told me to try pulling each DIMM of ram and trying each slot, as well as pulling the video card and trying the onborad video. Unfortunately since it's a Compaq I can't seem to find a MOBO for it because of the "proprietary configuration" as I was told. If the RAM and Video card don't solve this is there anything else I can check or should I cough up for a new system
? Does any one have any ideas as to what steps I should take next or advice on how to handle this? THANKS
