No Signal, No Beep, Fans Running, CD-ROM Drive flickering
thistimearound
When i was installing windows7 64bit, i got problems like irql_not_less_or_equal everytime i add/delete drive partitions and when installing. everytime the error shows up, i restart the pc and try again (forced to install). after several restarts and installs, i got the last error, something with hardware_interrupt, i cant remember it. after that, i restarted the pc again. and there's
no signal
no beeps
cpu fan running
dvd drive flickering
i dont know what's the reason, ;pls tell me so that i can replace dead parts of my cpu asap. i desperately need it now... my pc, my life :((((
Hello, and welcome to THG.
Seems like you have experienced a crash error, or BSoD.
Hardware_Interrupt could mean anything, really. Your BIOS has discovered a dad device, possibly your RAM.
Have you heard any beep codes during this fiasco?
BTW, what is your computer?
Reset your bios by removing battery on the motherboard this may help if some settings got funky. Also before installing Win 7 try disabling the floppy drive in the bios on some motherboards this can cause issues.
Try removing all your ram and just use one stick at a time also remove any unnecessary hardware that you do not need to get going like audio cards, unused drives, and remove any devices that you do not need connected to the USB ports. Also if you are using a dedicated GPU try using the onboard graphics if your motherboard has that option.
Fr0s3n
No beeps, I can how ever see the green power light so I do know some how it's getting powe.r I just don't see the cpu fan running. the old cpu fan worked fine , but when I replaced it with a new one it didn't spin at all. So I put the old one back on and now that's not working either.
Fr0s3n
i don't think it is the mobo itself, it has to be some thing easy on this matter , there is some thing I'm looking over. That very night I was on it and ran fine. that is untill I shut it down for the night the next morn "Boom" it wouldn't boot up.
Work systematically through our standard checklist and troubleshooting thread:
http://www.tomshardware.com/forum/261145-31-read-posting-boot-problems
I mean work through, not just read over it. We spent a lot of time on this. It should find most of the problems.
If not, continue.
I have tested the following beep patterns on Gigabyte, eVGA, and ECS motherboards. Other BIOS' may be different, but they all use a single short beep for a successful POST.
Breadboard - that will help isolate any kind of case problem you might have.
http://www.tomshardware.com/forum/262730-31-breadboarding
Breadboard with just motherboard, CPU & HSF, case speaker, and PSU.
Make sure you plug the CPU power cable in. The system will not boot without it.
I always breadboard a new build. It takes only a few minutes, and you know you are putting good parts in the case once you are finished.
You can turn on the PC by momentarily shorting the two pins that the case power switch goes to. You should hear a series of long, single beeps indicating memory problems. Silence indicates a problem with (in most likely order) the PSU, motherboard, or CPU. Remember, at this time, you do not have a graphics card installed so the load on your PSU will be reduced.
If no beeps:
Running fans and drives and motherboard LED's do not necessarily indicate a good PSU. In the absence of a single short beep, they also do not indicate that the system is booting.
At this point, you can sort of check the PSU. Try to borrow a known good PSU of around 550 - 600 watts. That will power just about any system with a single GPU. If you cannot do that, use a DMM to measure the voltages. Measure between the colored wires and either chassis ground or the black wires. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: 5 volts always on. Tolerances are +/- 5% except for the -12 volts which is +/- 10%.
The gray wire is really important. It should go from 0 to +5 volts when you turn the PSU on with the case switch. CPU needs this signal to boot.
You can turn on the PSU by completely disconnecting the PSU and using a paperclip or jumper wire to short the green wire to one of the neighboring black wires.
http://www.youtube.com/watch?v=5FWXgQSokF4&feature=youtube_gdata
A way that might be easier is to use the main power plug. Working from the back of the plug where the wires come out, use a bare paperclip to short between the green wire and one of the neighboring black wires. That will do the same thing with an installed PSU. It is also an easy way to bypass a questionable case power switch.
This checks the PSU under no load conditions, so it is not completely reliable. But if it can not pass this, it is dead. Then repeat the checks with the PSU plugged into the computer to put a load on the PSU.
If the system beeps:
If it looks like the PSU is good, install a memory stick. Boot. Beep pattern should change to one long and several short beeps indicating a missing graphics card.
Silence, long single beeps, or series of short beeps indicate a problem with the memory. If you get short beeps verify that the memory is in the appropriate motherboard slots.
Insert the video card and connect any necessary PCIe power connectors. Boot. At this point, the system should POST successfully (a single short beep). Notice that you do not need keyboard, mouse, monitor, or drives to successfully POST.
At this point, if the system doesn't work, it's either the video card or an inadequate PSU. Or rarely - the motherboard's PCIe interface.
Now start connecting the rest of the devices starting with the monitor, then keyboard and mouse, then the rest of the devices, testing after each step. It's possible that you can pass the POST with a defective video card. The POST routines can only check the video interface. It cannot check the internal parts of the video card.
