Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > help with setting up a wireless internet
Forum Laptops & Notebooks : General Laptops & Notebooks - help with setting up a wireless internet
Archived from groups: comp.sys.laptops (More info?)
i'm currently using an acer 270 travelmate laptop, and i was unsure of
the spec as its the wifes school computer.
does anybody no if this laptop can use pc card and a Wireless USB
adapter.
many thanks for any advise
Sponsored Links
>adapter.
Doesn't appear that that unit has internal wireless capability, but it
has three USB ports which could be used with a USB wireless adapter and
it has two cardbus slots which could be used for a cardbus wireless adapter.
Reply to Anonymous
would this work
LINKSYS WUSB11-UK Wireless USB adapter with US Robotics Wireless PC
Card 802.11b
or what would you advise,
i'm pretty new to this
thanks very much
Reply to Anonymous
>would this work
>Card 802.11b
>thanks very much
Don't really know what you are asking.
For a wireless network, you need some type of access point and a
wireless adapter in the computer (unless you are running an ad hoc
network, when two or more computers each have a wireless adapter but
there is no access point).
Any wireless access point should work OK (suggest one with 802.11b and
802.11g capabilities as well as WPA encryption).
Same goes for the wireless adapter. Any USB wireless adapter or cardbus
wireless adapter should work (but suggest adapters with b&g capability
Reply to Anonymous
still a bit confused would a wireless router and a pc card create a
wireless link
i've got a LINKSYS wireless-b broadband router and pc card
thanks for any help
Reply to Anonymous
wireless link
thanks for any help
Reply to Anonymous
: still a bit confused would a wireless router and a pc card create a
: wireless link
: i've got a LINKSYS wireless-b broadband router and pc card
Yes, as long as the router is hooked up to a broadband/DSL
connection and configured correctly. The broadband or DSL "modem"
will connect from the cable or phone line to your router.
If you can, test your connection with a wired connection before you go
wireless. To do this, you will need an ethernet "Cat5" cable. The
router should have ethernet plugs on the back of it in addition to
being a wireless access point. Plug the cable in to the router and
the other end into your laptop (if your laptop is modern, it should
have an ethernet connector). If this puts you on the internet, then
unplug the cable and try it wireless.
Andrew
----> Portland, Oregon, USA <----
----> http://www.bizave.com <---- Photo Albums and Portland Info
----> To Email me remove "MYSHOES" from email address
Reply to Andrew
thanks i'll give it a go
Reply to Anonymous
There are 989 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
