Thought process going into this build: I will say straight up front, I have been a mac person for the past three or so years. I still enjoy the OS and if I had my way I would be going that route but there are things that I will straight up admit that windows systems do better. The two qualities I am looking at in this build is power and expandability. For me these two areas are what macs are lacking in and it is these two qualities that I am going overboard on in this build.
Approximate Purchase Date: As soon as possible. If someone can provide me with a good reason to wait to a certain date I will consider it though.
Budget Range: Around 5000 US Dollars in the initial setup. ( though the lower the better )
System Usage from Most to Least Important: Photoshop, school work ( which can range from essays to graphic processing in photoshop, illustrator, etc. )
Parts Not Required:
Keyboard
mouse
monitor: Asus VK278Q Black 27" 1920x1080 2ms Full HD HDMI LED BackLight LCD Monitor w/Webcam 300 cd/m2 10,000,000 :1 (ASCR) ( http://www.newegg.com/Product/Product.aspx?Item=N82E16824236101 considering getting a 2nd if the opertunity presents itself. )
Power supply: Antec High Current Pro HCP-1200 1200W ATX12V / EPS12V SLI Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply ( http://www.newegg.com/Product/Product.aspx?Item=N82E16817371043
Preferred Website(s) for Parts: Really im up for hearing about any place you have gone that has given you good service in the past. For the most part all I have used so far is newegg. That is not to say that if you know of a place that has a good price on a part I'm looking for or that is suggested that I would not look there as well.
Country of Origin: Washington state USA
Parts Preferences: No real preference at all I would like to do things has cheaply and long lasting as possible.
Overclocking: Maybe, I have never done it and im hoping that with this system I won't really need to OC it at all until long down the road.
SLI or Crossfire: Yes, if anyone can give me a pref on what card and brand and such please do so following a discussion on why I should go that way, im not likely to buy something unless I understand why.
Monitor Resolution: currently 1920x1080, i may go and get another monitor later, still not sure yet.
CPU:
Intel Xeon X5680 Westmere 3.33GHz 12MB L3 Cache LGA 1366 130W Six-Core Server Processor BX80614X5680 ( http://www.newegg.com/Product/Product.aspx?Item=N82E16819117228 ) [$1,722.30]
Mobo:
EVGA Classified SR-2 270-WS-W555-A2 LGA 1366 Intel 5520 SATA 6Gb/s USB 3.0 HPTX Intel Motherboard (http://www.newegg.com/Product/Product.aspx?Item=N82E16813188070 ) [ $589.99 ]
Monitor:
Already noted.
RAM:
WINTEC 8GB 240-Pin DDR3 SDRAM ECC Registered DDR3 1333 (PC3 10666) Server Memory Model 3SH13339R5-8GR ( http://www.newegg.com/Product/Product.aspx?Item=N82E16820161382 ) [$219.99] I know one stick isn't a lot, but this build is suppose to be expanded upon as time goes on and I get money for additional parts. Also contrary to what EVGA tells people, I have seen instances online that show people using 8GB sticks of ram on their SR-2 Mobos. )
Graphics Card:
EVGA SuperClocked 015-P3-1582-AR GeForce GTX 580 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card ( http://www.newegg.com/Product/Product.aspx?Item=N82E16814130590&cm_re=gtx_580-_-14-130-590-_-Product ) [ $529.99 ] This is awfully expensive so if people can present a good reason to go with a 480 or something I am all ears.
PSU:
Already noted in existing parts
HDD: Not sure, if i can afford it I might get a small SSD or a TB HDD. I would love one or two SSDs but my fear is if my primary use is photoshop and I use the SSD as a scratch disk then won't that degrade its integrity quicker than almost anything else. Unless I got myself a ram disk ( which would be too expensive with this build ) it seems that flash based memory will not hold up well as a scratch disk so I might be better off investing in a raid or attempting to max my ram faster.
Case:
I need a lot of help here. There is the LIAN LI PC-V2120B Black Aluminum ATX Full Tower Computer Case ( http://www.newegg.com/Product/Product.aspx?Item=N82E16811112311 ) But at roughly $430 ( $460 if you wanna count shipping. . . ). The one I am currently leaning toward a Moutainmods U2-UFO http://www.mountainmods.com/u2ufo-cyo-choose-your-own-p-438.html with the additions I want comes to around $345 ( im not sure how much shipping will be. ). There is also the DangerDen Tower 29 ( http://www.dangerden.com/store/black-series-tower-29.html#tabs ) but I am not a fan of the single optical drive port. While I can get a combodrive and I would probably be fine I would feel kind of stupid if I found myself limited by my case in some way when I bought this computer with expandability in mind. Though atm DangerDen has a 15% discount on this case which sounds pretty nice and prices it around $342.46. Any help here would really help, I don't know much about these cases or how to configure the custom ones. Im also not sure what to have in mind as this is the first computer I am building so I would like to know what I should expect from each and if there are advantages to some over others. Also other suggestions would be great if you know of a case that will fit this mobo that is not one of these three, but keep in mind that im trying to go cheap, and I would really prefer to not have to mod the case in any way.
ODD:
Will probably salvage these from older computers.
OS:
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM - $99.99
or will see if I get a student discount on it somewhere.
This comes to about $3561.27 in parts I need. ( also not I have spent roughly 500 dollars on the monitor and power supply already. The whole build as it stands will cost around $4061.27. This leaves me with around 900 dollars to spend on storage, more ram and maybe even a SSD or something. But believe me if I can come out with a system that is under 5000 I would be elated. Might start to save for the next CPU or a cintuq or something. )
Is there anything I am missing, or does anyone have any suggestions. I know it looks blasphemous to be buying an SR-2 and not maxing it the hell out and OCing it to the point that I no longer have to heat my house on account that my computer now doubles as a space heater. They way I see it, some people buy a new computer every 3 or 4 years. With this one my hope is I will spend a fair amount of money on it initially, but by buying parts over time they will only get cheaper and will leave me with a computer that not only be high-end initially, it will also hopefully stay high-end longer than most do for a cheaper price. So by the time that 4 or so year period comes up I will have a computer that will last me another 4 or so years. I am also trying to buy top of the line parts in the hopes that I will not have to replace anything, I had trading parts out, it feels wasteful. . . I have no idea if this thought process is sound or not, none of my friends handle thier computers this way but they seemed intrigued by the idea. So why don't you all tell me what you think of this build and the main idea around it, and please do it in a thoughtful manner.
Parts Not Required:
Keyboard
mouse
CPU:
Mobo:
Monitor:
Already noted.
RAM:
Graphics Card:
PSU:
Case:
ODD:
OS:
