Hi,
I have previously put a thread about this about a month or so ago, but now I have already purchased most of the smaller bits and pieces although I am a little unsure about the monitor. Also, if you like to offer any other advice about the rest of the components, please feel welcome to add.
As I said, my main thoughts are for the LED monitor. Is this what I want for the best of both worlds of watching films and playing games. So much internet opinion on whether it has slower response rates than pure LCDs. Is it a sacrifice for the higher contrast ratio available on LED lit LCDs??? I noticed that above 24 inch, the pixel pitch on most brands increases to o.3+ of a mm, whereas on 24 inches and less its usually 0.274...maybe up close, you will notice a difference and make minor difference to the overall image clarity. Should I therefore for gaming purposes stick to 24 inches or 27 and move the screen further away? Hmm, but then again, it has the same pixel resolution. (I know, I am speaking from my head right now)
So, my component list is as follows:
Intel i7 950 CPU 3.06GHz
Coolermaster HAF X Black Tower Computer Case (PURCHASED)
Corsair 6GB (3x2GB) DDR3 1600MHz XMS3 Dominator Memory CL8(8-8-8--24) for i7 Motherboards TR3X6G1600C8D
Asus 1536MB GeForce GTX 580 GDDR5 NVIDIA Graphics Card
Asus SABERTOOTH X58 TUF Components series ATX Motherboard
Coolermaster Silent Pro Gold 1000W Modular PSU
120GB OCZ Vertex 2 3.5" SSD up to 285MB/s READ up to 275MB/s WRITE
Samsung HD103SJ Spinpoint F3 1TB Hard Drive SATAII 7200rpm 32MB Cache - OEM (PURCHASED)
LG CH10LS20 BD-ROM and DVD-RW Drive - CH10LS20.AUAR10B (PURCHASED)
All in 1 Internal Card Reader Plus One USB2 Port, Black (PURCHASED)
StarTech.com Bracket for 3.5 Inch Floppy with Bezel FOR ALL IN 1 CARD READER IN FRONT 5.25 BAY (PURCHASED)
COOLERMASTER MEGA-FLOW 200mm Transprent Blue LED Silent Fan 700rpm (PURCHASED)
25cm FlexLight 24 x 4mm Blue LEDs with connection cable (PURCHASED)
OS supplied from Uni 64 bit windows 7 (FREE)
Cyborg R.A.T.5 Gaming Mouse (PURCHASED)
Sennheiser PC 350 Gaming Headset with MIC
Asus VK246H 24inch Widescreen 2ms DVI HDMI LCD Monitor Built-in Webcam
