Hi, I'm really new to computer building. I did some research but I need your help to see if everything is fine.
I'm planning to build a computer mainly to play games at 1900 x 1200 resolution. Ideal budget is under 800$ CA but could be stretched a bit if really necessary. Please keep in mind I usually keep my system for 3-5 years. Local retailer came with this offer:
Intel Core i5 760 2.8GHz LGA1156 Socket FC-LGA8 L3 8 MB Box 229,95$
Asus SKT 1156 H55 mATX 84,95$
Kingston ValueRAM 4GB (2x2GB) DDR3 1333MHz PC3-10600 CL9 1.5V KVR1333D39K2/4G 69,95$
High Power 750W (HP-750) 59,95$
MSI GeForce 460 Hawk Talon 1GB 256-Bit GDDR5 PCI-E 2.0 239,95$
Total: 684,75$ + tx = 772,91$
Is it enough for long term gaming and is it worth the asking price ? Also i was wondering if I should go with 1090T AMD instead or even a core i7 870 or is this overkill (3-5 years) ? And is a non SLI system enough with this card ?
Thanks a lot for your help.
