Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > warning: don't buy batteries from Power Express
Forum Laptops & Notebooks : General Laptops & Notebooks - warning: don't buy batteries from Power Express
Archived from groups: comp.sys.laptops (More info?)
I've bought 2 replacement batteries for my ThinkPad A31 from Power Express.
The first completely failed after a few months, and the second (free
replacement) came with instructions to "condition" it by deep cycling it 5
times. It came with an initial health capacity of 38 WH (and the IBM
battery it replaced had one of 43WH), and after the 5 cycles, it's now down
to 29WH. No answer from them when I ask about these batteries failing so
quickly.
The temp in the battery has never exceeded 26C when charging or operating.
They list the manufacturer as "PS" and the model as "IBM compatible".
Anyone else have a suggestion for quality ThinkPad batteries (other than
IBM, who want almost $300 for one!).
thanks.
Chip
Sponsored Links
Li-Ion batteries should not be cycled. It sounds like the battery you
replaced was a Ni-Mh battery and the new one is LI-ION. Ni-MH is 4.5 AH and
Li-Ion is 3.6 AH. Some of these sites put the wrong part number on the
battery type. ....
"Chip Orange" <acorange@comcast.net> wrote in message
news:U8KdnXcIH9Cx7ZzfRVn-1Q@comcast.com...
> Express. The first completely failed after a few months, and the second
> (free replacement) came with instructions to "condition" it by deep
> cycling it 5 times. It came with an initial health capacity of 38 WH (and
> the IBM battery it replaced had one of 43WH), and after the 5 cycles, it's
> now down to 29WH. No answer from them when I ask about these batteries
> failing so quickly.
> thanks.
> Chip
Reply to woody
Thanks for the response; but, the battery health and information utility for
the original, and the replacements, have all shown the chemistry to be
li-ion.
The original shows a design capacity of 43 Wh, while these replacements show
a design capacity of only 38 Wh. That in itself is a troubling difference,
but both of the replacements are degrading at an extraordinary rate. The
first use date by the way also is only a couple of months ago, and the cycle
count was 0, so, if it was a reconditioned battery then they had some way of
resetting the info on board.
"Woody" <TheDuck@pond.net> wrote in message
news:rKeMd.99$hU7.72@newssvr33.news.prodigy.com...
> and Li-Ion is 3.6 AH. Some of these sites put the wrong part number on the
> battery type. ....
>> (and the IBM battery it replaced had one of 43WH), and after the 5
>> cycles, it's now down to 29WH. No answer from them when I ask about
>> these batteries failing so quickly.
>> operating.
>> thanks.
>> Chip
Reply to Anonymous
Would you be kind enough to post the precised battery make here for
us? Read off the label. I assume Power Express is just some sort of
a middleman.
Reply to Anonymous
SAYS "NIB031" and then it goes on to say "replaces ..." a long list of
battery model numbers, including the one I'm interested in, 02k6897
Does this help?
It
"bobb" <None@NoWhere.com> wrote in message
news:2623019jp0i4kdhnk879m1tl7vkp85dafd@4ax.com...
> a middleman.
Reply to Anonymous
On Wed, 2 Feb 2005 21:45:29 -0500, "Chip Orange"
>Does this help?
>It
No Five-Stars Enterprises? Dragon Power? Made in China?
Reply to Anonymous
There are 1193 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
