Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > wireless LAN card PA3266U-3MPC in Satellite A-10
Forum Laptops & Notebooks : General Laptops & Notebooks - wireless LAN card PA3266U-3MPC in Satellite A-10
Archived from groups: comp.sys.laptops (More info?)
Hi.
Have just installed the above but don't seem to be having any joy
getting the Satellite to recognise it.
Any suggestions?
d
David Ould
http://ould.bravehost.com
Sponsored Links
David Ould <davidNOSPAMould@hotmail.com> wrote:
: Have just installed the above but don't seem to be having any joy
: getting the Satellite to recognise it.
: Any suggestions?
Can you provide some details? Did you check device manager? Is the
card seen at all? Did ANYTHING happen after you plugged it in? Is
there a BIOS setting to enable the mini-PCI slot?
Andrew
----> Portland, Oregon, USA <----
----> http://www.bizave.com <---- Photo Albums and Portland Info
----> To Email me remove "MYSHOES" from email address
Reply to Andrew
> : Any suggestions?
> Andrew
thanks Andrew
It's not seen on device manager nor was there any plug and play magic
when it was turned back on.
I'll check the BIOS and report back.
David Ould
Reply to Anonymous
: It's not seen on device manager nor was there any plug and play magic
: when it was turned back on.
: I'll check the BIOS and report back.
Are you sure that the mini-PCI slot is even hooked up in the laptop?
Or did you just find it on the laptop and assume you could put a card
in there? (Did you find an internal antenna in there to hook up as
well? If not - that doesn't bode well...)
Andrew
Reply to Andrew
all sorted!!! It turns out I was way too gentle installing it. Opened up
the box and shoved it in good and proper. All working now.
Thanks, though, for bothering to want to help even when I gave sod all
info :-)
David Ould
Reply to Anonymous
There are 677 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
