Solved
What to Do With Unused Power Connectors?
Last response: in Components
Noob wading into the waters. :o
Best to ask my question with an example: The processor power connector on my motherboard has 4 pins. If I get a power supply with a 4+4 pin processor connector, what happens to the unused 4-pin connector? Do I cover it with electrical tape? I mean, here's this wire with one end plugged into a power supply and the other end roaming free, just waiting to cause a short circuit if it comes into contact with something conductive.
Best solution
The contacts on PSU power connectors are recessed in a plastic casing, the metal inside cannot make contact with anything outside unless you shove something in there, like the contacts of the connector its supposed to go in, or something bad like a fork. You can leave the other 4 pins roaming free, it doesnt have the ability to make a short with anything conductive by accident.
I usually tidy everything up with some small zip ties of the same color as the rest of the computer to keep it looking nice and uniform.
Edit
I forgot to mention though I am really anal about how the wiring looks it really doesn't matter as long as the wire is not touching any fans or blocking airflow it does not matter.
Ask the community
