Hi all,
First post, here...
I need to get this card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130550&cm_re=geforce_gtx_470-_-14-130-550-_-Product
To run in this machine: http://www.newegg.com/Product/Product.aspx?Item=N82E16883114065&cm_re=et1161-03-_-83-114-065-_-Product
What's the best way to figure out what power supply I should use?
My only other hardware I need connections for inside are an EIDE DVD-DL drive and 2 SATA HDDs. And obviously that new video card.
Where do I start? I've never done this kind of upgrade before.
Thank you!!
First post, here...
Thank you!!
