Sabertooth 990FX chipset problems
Related ressources:
- ForumAsus sabertooth 990fx chipset drivers
- ForumNew Sabertooth 990FX Build with lots of Problems
- ForumCannot install windows on sabertooth 990fx sata 2 disk
- ForumAsus Sabertooth 990FX CPU LED
- ForumSabertooth 990FX HELP!!
- ForumTrouble getting ASUS AI Suite II to install on Sabertooth 990FX
- ForumAsus Sabertooth 990FX - Sluggish
- ForumSabertooth 990FX POST Boot Device Error
- ForumLooking for Opinions on ASUS Sabertooth 990FX vs. Crosshair V Formula
- ForumIs this RAM compatible with ASUS Sabertooth 990FX ?
- ForumHelp updating BIOS
- ForumSabertooth P67 + memory stick problem
- ForumSabertooth 990FX + FX 8150 = impossible?
- ForumSabertooth x58 no post
- ForumI got a big problems with my computer-low memory
- Forum[Solved] Sabertooth 990fx - Possible Bios Update Issue
- ForumWhich Chipset Motherboard to buy H67, P67 or Z68
- ForumMSI Hydra Lucid Chipset
- ForumProblems with installing the operating system
- ForumSabertooth x58 problem?
- More resources
Read discussions in other Motherboards categories
The problem came when I tried to install the chipset drivers from the installation disc that came with the mobo. During installation, all that pops up is a DOS window and another smaller window saying 'installing sofware'. After a few seconds they both disappear and I get no confirmation of installation, no reboot prompt, no nothing. And as soon as I restart my PC, everything boots up as normal until I get to the Windows 7 login window... or what should be the login window. All I can see is the white cursor. The screen is just black, there's nothing but the cursor. I can move it around and it's responsive to my mouse and everything, the screen is just empty. I've rebooted several times and it's always the same. If I put my Windows 7 disc in and boot from that and do a system restore to before I installed the chipset drivers, everything goes back to normal and I can log on just fine. I've re-installed Windows at least 3 times and every time I get the same problem when installing the Chipset drivers. I've tried installing them from the disc and I've downloaded them from the ASUS website. Always the same result.
PC spec is below if it helps. Thanks so much to anyone that can help!
