Connecting 5.1 surround sound system to my computer
Last response: in Components
Hey all,
Yesterday I bought a Logitech 5.1 X-540 speaker set for a measly $48 on sale and Im wanting to hook them up to my pc for proper surround sound. I currently only have the green 2-channel 3.5mm plug connected as my pc doesnt have the black (rear) and orange (center/sub) 3.5mm outputs that the speaker set also has as I am only using my onboard soundcard. But I did find a connector that im guessing connects to the motherboard to give me the extra surround outputs. So my question is, would I be able to plug this connector to my motherboard and then connect all three 3.5mm jacks on my speakers to my sound outputs on my pc so I am able to make full use of all my speakers?
Heres a photo of the surround sound connector I found lying around:
https://c5fvfw.bay.livefilestore.com/y1palaG9zXcQhUTEFU...
Heres my motherboard:
http://www.gigabyte.com/products/product-page.aspx?pid=...
And the speakers:
http://www.logitech.com/en-us/439/234?WT.z_sp=Image
I'm confused; does your motherboard not have the necessary 7.1 jacks built right in to the rear panel? I haven't seen a mobo without 7.1 support built right in for years now...
how does the surround sound connector you found interface with the motherboard?
edit, I saw it above your hand in the pic. Thats the HD audio connector. Count the pins. I dont see a compatible header on the mobo.
Thanks everyone for the replies. I tried plugging all three 3.5mm plugs from the speakers into the 3 sockets in the back of my pc (green, pink and blue) and even though the pink was marked as a mic input and the blue some other type of sound input/output, after fiddling round with the Realtek HD Audio Manager settings, I managed to get everything working :)
Ask the community
