I recently ordered the raidmax 730w psu
http://www.newegg.com/Product/Product.aspx?Item=17-152-036&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=5&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page
and the raidmax smilodon case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156063&cm_re=smilodon-_-11-156-063-_-Product
I was wondering if the fan on the power supply unit would be a problem, because if i mount it facing up the fan will be very close to the top of the case. Would it hurt to mount it upside down, so that the fan is intaking/blowing into the case, where a 120mm exhaust fan sits just below it?
