Would like a few comments on temperatures on this new build … the temps below are idle temperatures … just using Word … and light browsing … max cpu core and gpu temperatures so far playing Call of Duty Black Ops have been 46 deg C for cpu and same for GTX … with this cpu cooler … does this seem reasonable … no overclocking on anything … haf 922 front and top fans running off molex (full power but quiet) … thanks for comments … John
Mainboard Model P7P55D-E PRO (0x00000308 - 0xA186ADE0)
Hardware Monitors
Hardware monitor Winbond W83627DHG
Voltage 0 1.14 Volts [0x8E] (CPU VCORE)
Voltage 1 1.75 Volts [0xDB] (VIN1)
Voltage 2 3.41 Volts [0xD5] (+3.3V)
Voltage 3 5.11 Volts [0xD5] (+5V)
Voltage 4 11.93 Volts [0xD6] (+12V)
Voltage 6 0.96 Volts [0x78] (VIN6)
Temperature 0 30°C (86°F) [0x1E] (SYSTIN)
Temperature 1 30°C (86°F) [0x3C] (CPUTIN)
Temperature 2 29°C (83°F) [0x39] (AUXTIN)
Fan 0 1148 RPM [0x93] (SYSFANIN)(rear case fan)
Fan 1 861 RPM [0x62] (CPUFANIN0) (set in bios to quiet standard)
Hardware monitor Intel Core i5 750
Power 0 60.66 W (Processor)
Temperature 0 31°C (87°F) [0x44] (Core #0)
Temperature 1 28°C (82°F) [0x47] (Core #1)
Temperature 2 29°C (84°F) [0x46] (Core #2)
Temperature 3 27°C (80°F) [0x48] (Core #3)
Hardware monitor NVIDIA GeForce GTX 460
Temperature 0 24°C (75°F) (GPU Core)
Ambient room temperature … 66 deg F
Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) 1.65v … 9-9-9-24
ASUS P7P55D-E Pro LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
MSI N460GTX CYCLONE 1GD5/OC GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5
SAMSUNG Black 22X DVD+R 8X DVD+RW 22X DVD-R 16X DVD-ROM 48X IDE CD/DVD Burner
COOLER MASTER Hyper 212 Plus
COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
ASUS VH222H-P Black 21.5" 5ms HDMI Widescreen Full HD 1080P LCD Monitor
OCZ Agility 2 OCZSSD2-2AGTE60G 2.5" 60GB SATA II MLC Internal Solid State Drive (SSD)
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache
Hardware Monitors
