Is my problem my CPU?
Last response: in CPUs
Related ressources:
- ForumProblem with CPU overheating!
- ForumCPU Watts problem
- ForumProblem with new CPU
- ForumPCIe 3.0 GPU, CPU only supports PCIe 2.0. Problem ?
- ForumVery Puzzling problem CPU /Mobo or something else?
- ForumMemory or CPU /MB problem
- ForumBad CPU ? i7-2600k Could use some help pinning down problem .
- ForumHelp with a CPU Problem
- ForumCpu Heat Problem
- ForumCpu power problem
- ForumOverclocking my cpu ( problem ) Boot problem
- ForumIs this a problem with my CPU or GPU?
- ForumGTX670FTW problem : or CPU bottleneck
- ForumAMD CPU Cooling Problem
- ForumCPU Problem
- ForumWhats the most likely problem ? CPU or mobo
- ForumHelp with what motherboard and cpu to buy/help with pc problem
- ForumProblem with CPU Cooling.
- ForumCPU spikes, computer slower response times. What's the problem ?
- More resources
The cpu is an Intel P4 3.0 ghz with HT. I have heard of these going bad, and nothing else is broken, so I want to double check with the forum to make sure that my CPU is what needs replacing. (BTW: the replacement costs $23.)
