i just set up my wireless internet with a lynksys router...the wireless is working and connecting fine...but now my desktop internet isnt working at all...help!!
Which one do you want to use? Wireless or Ethernet? You can't use both at the same time. If you disable the wireless interface, then the Ethernet should work fine.
