My computer had been running fine, then started freezing just after startup. It would boot into windows and my programs that were set to start automatically would open, but as soon as I tried to do anything else (open a browser window, etc) it would become completely non-responsive. It was time for a reformat anyway, so I did that to rule out any software problems. It made it through the installation of Windows 7 (same OS as before), but as soon as the desktop loaded it froze again, and did this every time consistently (as it did before the reformat). This confirmed that it was a hardware problem.
I did what I believe is standard procedure - removed everything but 1 stick of RAM and the processor, and unplugged all accessories other than keyboard, mouse, and monitor. Mobo has on board graphics, which I don't use, but am currently using to rule out graphics card problems. Computer starts fine like this, and as expected gets to the screen that displays "Reboot and select proper boot device..." I first tried connecting a sata optical drive with the Windows 7 disc in it. It worked fine and got to the installation screen and as expected there was no hard drive to install windows on. Then I tried connecting a sata hdd. it hangs up on the "detecting storage devices". I have three different hard drives that were all in the computer when it was running smoothly (two are a few months old, one is a little over a year old), and 6 sata ports. I tried the 3 different hard drives in a variety of sata ports and they all had the same result. It hangs regardless of whether the optical drive is connected or not. After my experiment, with only the optical drive connected which worked before, it still hangs in the same place. With nothing connected other than the extreme basics, it does what it did before i started playing around with sata ports (gets to "reboot and select proper boot device"). So... whatever the problem is it got worse.
What to replace? As far as I can tell its either PSU or mobo. I haven't tested the hard drives or optical drives in another computer because I don't have another desktop, but it seems unreasonable that they would all fail at the same time unless the mobo or PSU somehow damaged them. Power supply and mobo are both about a year and a half old, part of a prebuilt HP that has been upgraded in other areas. If it could be something else, please let me know.
My reasons for suspecting mobo: The issues with the sata ports not working. Also, I attempted a mod from another thread. I tried to use a soldering iron to open the end of one PCIe x1 slot to put another pcie x16 video card in it, but my not so steady hand failed me. I really don't think this is related because I didn't damage the mobo really, I just did a bad job of melting the plastic and pushed it in slightly so a card does not physically fit properly. Again, I didn't touch any connections or anything, just some excess plastic, and the computer ran as normal afterwards for a time.
My reasons for suspecting PSU: I have recently (worked fine for a few days) been using an upgraded graphics card which google tells me requires a minimum of a 350W PSU, which is exactly what the prebuilt came with. I'm also running 3 HDD so I should probably require more than 350W PSU, meaning mine has been getting overworked. I have no idea how PSU failure occurs, and if its possible that it would still power the basics and only the sata device connections could fail, or if PSU's fail all at once, or ...?
I'm an Engineering student (civil, not computer related as I'm sure you can tell) and really need to get this thing running again to get my final projects done, so I'd be grateful for any quick advice. My ooolldd laptop doesn't handle CAD so well.
Oh, I just ordered a new PSU (before failure) because I knew mine was quite taxed. It wont be here for several days though, so I'd still really like to try and figure this out before I get a chance to try the new one. Can't really afford to wait for it to come and then have to wait for a mobo. Thanks all!
