[System Upgrade] Which to invest in first?
Hello all,
I'm afraid I'm rather new to these forums, but I was hoping some of you may be able to offer a little advice about upgrading my system. I mostly use my PC for games and don't want to spend more than $250 at this time. Currently I have:
Mobo: ASUS P5NSLI
CPU: Intel Core2Duo e6600 2.4 GHz
RAM: 2gigs, DDR2 667
Vid: Nvidia 8800gt, 1gig
My question is, I hope, a simple one to the experienced rigger: Which of these components stands out to you as the one in need of an upgrade the most?
I've been considering a few options such as
1) Upgrading my cpu/mobo/RAM. I think this is the most expensive route and I don't think it will fit my current budget.
2) Upgrading my video card. I know there are pretty good cards available for about $170 - $200, but will my aging CPU/mobo hold a new card back?
3) Finding another 8800gt and going SLI. I'm again a little reluctant because these cards are going the way of the dodo.
4) Buying a couple more sticks of RAM. My mobo has a couple of open slots and I think this is by far the cheapest option, but will I really see much performance boost?
5) Upgrading my CPU alone with another 775 with better performance. My mobo is too old for a quad core (I think) but there are better Core2's out there.
Thank you for any help you could render and again, I'm sorry if I put this post in the wrong place.
1 answer Last reply
More about system upgrade invest first
  1. how attached are you to intel? you could probably get a decent am3 board, cpu and ram for 250 and it'd be a huge upgrade leaving room to upgrade the cpu evn more in the future
New Build Systems
