Tom's Hardware > Forum > Digital Camera > Digital Camera General > Noise Ninja custom noise print- worth the effort for stack..
Forum Digital Camera : Digital Camera General - Noise Ninja custom noise print- worth the effort for stack..
Archived from groups: rec.photo.digital (More info?)
I am an amateur astronomer and use a digicam to take pictures of the solar
system. I take up to 100 photos and then stack the photos into one to
reduce noise levels. However, sometimes a 100 photo composite isn't enough
for the amount of noise I get. I have Noise Ninja, but don't use it much
because I am never happy with the results as it seems to smooth the images
too much, washing out details. However, I have never created a custom noise
print for my camera, using the checkerboard pattern and a defocused shot.
My big question is: would a custom noise print created this way be worth the
effort and would the results be better than just the box sampling I do now
from the existing image? Also, I'm guessing that I would need to take 100
such samples since 100 images make up a composite, but not sure how to go
about it. I would think that each image would have to have noise reduction
before stacking for this to work and that's how I was going to do it. So,
yes, a lot of effort involved, but would the result be worth it?
Thanks,
Jason Sommers
Sponsored Links
"Jason Sommers" <jsom@edt.met> wrote in message
news:macHd.4477$Rs.1449@newsread3.news.atl.earthlink.net...
> pictures of the solar system. I take up to 100 photos
> and then stack the photos into one to reduce noise levels.
If reducing the random noise by a factor of 10 isn't enough, you
should indeed investigate post-processing noise reduction per image
(assuming you cannot reduce noise by preventing it). Do you do
darkframe/offset/bias/etc. subtraction?
> I have Noise Ninja, but don't use it much because I am
> images too much, washing out details.
I'm more familiar with Neat Image, but these programs are probably
equally suitable. Spend some time in tweaking the settings (often
means reducing the default amount of reduction).
> However, I have never created a custom noise print for
> defocused shot.
You should, as there is no suitable featureless area in deepspace
images you could use to create a noise profile. Do make sure that you
don't make this profile until the darkframe subtraction etc. has been
done first.
> this way be worth the effort and would the results be better
> than just the box sampling I do now from the existing
> image?
Although it's hard to judge without examples I am almost certain it
will improve things a lot. A program like Neat Image can run
unattended in batch mode once you've figured out the optimal settings.
> Also, I'm guessing that I would need to take 100 such
> not sure how to go about it. I would think that each
> image would have to have noise reduction before
> do it.
Yes, individual noise reduction per image (in batch mode), not on the
stacked result.
> So, yes, a lot of effort involved, but would the result be worth it?
Again, make sure you've done all you can to prevent the noise in the
first place, because all post-processing carries the risk of signal
loss. There would be not much benefit if the noise reduction doesn't
improve the S/N ratio.
Bart
Reply to Anonymous
solar
to
> reduce noise levels. [...]
worth the
do now
You take a hundred images and wonder if a few more is worth it? You
have a weird "effort" calculus.
But whatever.
I can't comment on "Noise Ninja" (which, in the absence of other data,
sounds more like marketing than principled noise reduction -- but
perhaps silly names are an indication of a saturated market than
anything else), but whatever "custom noise print" you may record with
your sensor most likely won't hold up once you start stacking up
mis-aligned frames.
If it was me, I would just stack up several hundred images, not just a
mere hundred. This is, after all, what everyone else does:
http://www.trivalleystargazers.org [...] aturn.html
Many other hits. Also note that stacking is the only way to reduce
noise without sacraficing image detail (or, equivalently, making
assumptions about the structure of the image -- assumptions which Noise
Ninja and its ilk necessarily make.)
Reply to Anonymous
<eawckyegcy@yahoo.com> wrote in message
news:1106076593.038163.72480@z14g2000cwz.googlegroups.com...
> solar
> to
> worth the
> do now
Not sure what you mean by this "effort calculus" but in astronomy, one is
limited by the rotation of the object being imaged. This isn't much of a
problem with wide field deep space objects, but with narrow field planets,
which will show a "rotational blur" after a surprisingly short time, the
total number of stacked frames is limited. I can only capture about 100
frames at a time with my digicam before rotational blur becomes an issue,
but with dimmer targets like Saturn, 100 frames isn't enough and, other than
increasing telescope aperture, I am trying to find the next best way to
reduce noise.
> But whatever.
> mis-aligned frames.
Like I said, digicams are not capable of that. I haven't looked at the
link, but some use webcams, which can do this, but I don't like the dynamic
range of webcams which is why I've stuck with my digicam.
That's true, but once you reach your stacking limit and noise is still an
issue, you seek out other options which is why I was asking about going to
the trouble to make a noise print.
Jason
Reply to Anonymous
one is
My meaning should be clear: if you can find the time to take 100
images of something, an extra few for a "noise print" are in the
"effort noise".
I've seen Saturn images from stacks of over a thousand frames. What
kind of "digicam" are you talking about here? Basically everyone is
mangling web or video cameras into some shape or another for this work.
If you aren't doing likewise, then either you have innovated something
markedly new and worthy of publication (e.g., stack projections of your
images, not the images themselves, thus solving the rotation problem),
or you are mis-engineering a solution.
Reply to Anonymous
news:1106090788.200731.30490@c13g2000cwb.googlegroups.com...
> one is
> "effort noise".
In other words, I think you're saying just take an extra 100 "noise print"
shots at the time. Well, that is what I will do in the future but with the
existing frames, noise prints will have to be created after the fact-
something I am considering and was the point of my original question because
it means a lot more work.....
Perhaps, but it's rare to find a sharp solar system object with that many
frames. There is a tradeoff. Reducing noise by stacking more frames than
necessary causes smoothing and loss of detail.
What
A Coolpix 4500. Yes, webcams seem to be at the forefront, but the dynamic
range still suffers even after stacking many many frames. Digicams, and
likewise commercial astronomy CCD cameras, are capable of producing better
images IF noise is not an issue.
I appreciate your analysis, but it deviates from the point of my original
question.
Jason
Reply to Anonymous
There are 702 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
