Solved
First time build! need help!! ~1000
Last response: in Systems
Hi guys, im new to building a computer and was looking to spend around $1000 on it. Also, it is strictly for gaming, and I am looking to be able to new/most games max. (i.e. crysis, black ops, starcraft..). I did some researching around and came across this build:
Mainstream Gaming Computer | Hardware Revolution
It looks good and fits the budget, but with some minor tweeking from you guys, lol.
**note: I need help deciding the mobo & case so it will work with gtx 460 in sli***
CPU: i5-760
Newegg.com - Intel Core i5-760 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core Desktop Processor BX80605I5760
CPU cooler: COOLER MASTER 212
Newegg.com - COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm "heatpipe direct contact" Long life sleeve CPU Cooler
Mobo: ASUS Maximus III Formula LGA
Newegg.com - ASUS Maximus III Formula LGA 1156 Intel P55 ATX Intel Motherboard
GPU: 2 EVGA gtx 460 sli
Newegg.com - EVGA 768-P3-1360-TR GeForce GTX 460 (Fermi) 768MB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
PSU: CORSAIR 650W
Newegg.com - CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
Ram: 4GB G.Skill
Newegg.com - G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
HDD: Western Digital 640GB
Newegg.com - Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Case: COOLER MASTER sotrm scout
Newegg.com - COOLER MASTER Storm Scout SGC-2000-KKN1-GP Black Steel / Plastic ATX Mid Tower Computer Case
Total: $1,064.91 ~ before rebates
**If anyone could guide me as to items I can probably cut costs in and if I am missing anything, I would really appreciate it!**
Thanks!
More about : time build 1000
^ If it is going to be purely a gaming PC, then why not check out AMD? They would be cheaper and offer as good performance in gaming(with regards to the CPU)
Some changes
X4 965 + 790X
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
If you want SATA 6GB/s and USB 3.0
2x HD 6850s
CASE -
Additional fans
HDD
DVD
Rest same...
Thanks for the feedback, although I think I am going to stick with the intel (fanboyism) and I kinda want the sli 460s. Gunna take out the dvd rom out of my old computer because Im personally fine with it.
Also, I don't really care about usb 3.0 and don't really know what the SATA 6GB/s is. lol
Thanks again.
Related ressources
Great, thanks a lot.
So I re-edited the build and took your advice with the mobo and the gpu.
Im going for the ASRock + 2x 6850 CF...650W is still plenty for this correct?
Oh, also, what monitor would you recommend? (planning on getting it down the line)
Updated:
i5-760
ASRock Motherboard
6850 CF
Cooler Master 212
Corsair 650W
Samsung HDD
4GB (2x2) ram G.Skill
total: 904.91 (without the case- still researching on them)
Best solution
Before choosing the board, just make sure which CPU it supports...
The ASUS P7P55D which I linked is the one that supports the i5 760...That ASRock board I linked is for AMD CPUs
CASE -
Monitor - Not sure how long this price will stay
Asus VE228H 21.5" Full HD HDMI LED
$159.99
$149.99 after mail-in rebate card
Ask the community
