Hello,
I want to upgrade my gpu from a gts 250 to a gtx 460 1gb, but I have lost the 6 pin power connectors that came with my 850w Powercool psu. My current gts 250 uses 1 6 pin adapter which is currently using a 2 molex to 1 6 pin converter.
The Gtx 460 needs 2 6 pin adapters, if I split my 2 molex adapters into 4 molex adaptors to convert in to 2 6 pin adaptors will this work do you think? Or could I plug both molex converters I already have in so that each one is plugged into only one molex instead of two making 2 6 pin ports?
