I installed my new gtx 480 today(finally got my new PSU) im my pc and something weird has started to happen. Before I get the choice to choose which account I want to login in to, a chunk of the screen is missing like its got a bad resolution.
Once I get to login part screen, the resolution goes back to normal. Anyone know whats up?, I tried installing drivers with no luck, I can say one think though the card almost doesnt fit in the tower, its a tight fit and Im thinking the problem could be caused by it been a bit loose.
Also, another weird thing that happened is when I was testing out some games with my new card the first time I ran metro 2033 I had between 70-110 fps. Now its down to been between 30-50-60ish fps, I never changed the settings so its odd.
Current setup
Intel Core 2 Extreme QX9650 @ 3.0GHz 3000MHz
4 Gig DDR2-SDRAM
GTX 480
Current setup
4 Gig DDR2-SDRAM
GTX 480
