Built first computer and have problems
MB ASUS|M4A89GTD PRO/USB3 RT
AMD Phenom II x4 965 Black Edition
4gb Gskill
sapphire radeon 6850
antec 500w psu
I turned it on the first time and all the case fans turn on and the heatsink fan, they all run fine, but I get nothing on my monitor just a black screen and it seems like nothing is even being sent to the monitor because its like in power save mode. I have a green LED on the mobo, and I don't have a speaker on the mobo atm so was just looking for some help if anyone else has had this problem.
Thanks
3 answers Last reply
More about built computer problems
  1. also my cpu power connector is a 4pin w/ another 4 pin covered but my psu doesn't have any 8 pin connector so could I uncover the cover 4 pin and put two 4 pins in there instead of an 8
  2. If you need, you might try a Adapdor http://www.xoxide.com/tt-psu-adaptor-cables.html
Homebuilt Systems
