[strike]HEY, THERE IS PROBLEM OCCURING WHILE INSTALLING WINDOWS 7 TO MY LAPTOP. I HAVE FORMATTED THE ALL THREE DRIVES AND THEN DELETED THE TWO DRIVES AND NOW ONLY ONE DRIVE IS PRESENT OF 298 GB. BUT WHILE I TRY TO CREATE THE PARTITION BY PRESSING NEW NOTHING HAPPENS. THE FORMAT OPTION HAS GONE. AND WHILE I TRY TO TO INSTALL THE WINDOWS 7 IN THE SAME 298 GB DRIVE - IT SAYS -- setup was unable to use the existing partition because it does not contain the required free space.[/strike]
Edit:
Hey, there is problem occuring while installing Windows 7 to my laptop. I have formatted the all three drives then delete the two drives and now only one drive is present of 298 GB. But while I try to create the partition by pressing new nothing happens. The format option has gone. And while I try to to install the Windoes 7 in the same 298 GB drive - it says -- setup was unable to use the existing partition because it does not contain the required free space.
Edit:
