Power Supply Bad?
Last response: in Components
I have an Apevia Warlock 750W Black Alum. PSU w/ Multi-LED. I have 4 corsair dominator ram modules that have gone bad after I have already RMAed them. So I am wondering if the power supply is just junk. Using CPUID hardward monitor, here are the voltages it shows:
Voltages Value Min Max
CPU VCORE= 1.33v 1.33v 1.33v
VIN1= 1.18v 1.18v 1.18v
+3.3v= 3.34v 3.33v 3.34v
+5v= 5.08v 5.08v 5.08v
+12v= 12.16v 12.10v 12.22v
-12v= -8.58v -8.58v -8.58v
-5v= -4.74v -4.74v -4.74
+5v vcch= 4.73v 4.73v 4.73v
VBAT= 3.34v 3.34v 3.34v
Thinking I might need to get a better power supply as some of these look off but not sure. Any help would be appreciate. Thanks.
More about : power supply bad
o1die said:
I would rma the motherboard and get a spare ps for testing.
I have already RMA the board several months ago. I did notice these voltages were similar...even after I RMAed the power supply too.
o1die said:
Good power supply brands: corsair, antec, seasonic, enermax, and some ocz models. Apevia is not (tier one, the best under load).
Yea, I was thinking apevia wasn't that great. I was looking at an ultra x4 power supply the other day that had some great reviews. So, would you think that it might be just a crappy power supply that is not giving out enough juice to the ram and making them faulty? Which I would then go ahead and invest into a new power supply...just want to make sure I get this resolved as I am tired of sending hardware for RMA. lol
Ask the community
