Hello all. First off this is my first build. Had a small nightmare with Windows (tried dragging an upgraded version from a previous PC and didnt work- had to do clean install. So I am up and running and really have 2 questions:
1: my temps on my CPU in BIOS reads CPU- 38 C/100F then Mobo 28 C/82F- am i supposed to freak out on the "F" number or remain calm going by the C number? (Forgive my ignorance)- CoreTemp shows idle 33-35C and underload as high as 47C
2: RAM- I was BSOD several times and adjusted the BIOS to read 1333 and upped voltage to 1.5 (was at 1.32): was I right in doing this? have not blue screened since. The timing settings also dont reflect the timing sticker on the ram- should I be concerned to make adjustments?
Thanks!
Build:
M4A77TD Asus mobo
Phenom II X4 3.4ghz
4gig AData 1333G series RAM
Xigmatek Loki SD963 cooler
XFX Radeon HD5670
Case is an Antec 300- 3 120mm intake/ 1 140mm & 1 120mm exhaust
Hec Compcase 575watt PSU
Thanks!
Build:
M4A77TD Asus mobo
Phenom II X4 3.4ghz
XFX Radeon HD5670
