Just built my first computer specs are listed:
I5 2500k
CM 212 Evo
Asrock p67 Extreme 4 Gen 3
Gtx 580
Corsair Hx 750
hp dvd1260
WD 500gb caviar black
g.skills ripjaws 2x4gb
So i got the build complete, went to the bios and selected the HDD, rebooted and successfully installed windows7. Inserted the asrock mobo drivers disk and completely installed everything for that. Then i inserted the GPU drivers disk (its an EVGA 1536mb version) selected the recommended downloads and told it to reboot now. It rebooted but stopped at the asock screen where it gives you the option to run uefi setup, instant flash, select boot menu, and to switch screen. It will not move and when i hit the button for one of the options it does nothing. I have rebooted, ensured the hdd is plugged in, removed the gpu disk and still nothing it just sits at this screen. I have no clue what to do and need help, can't find any answers on any of the forums. Thx in advance for any help!
I5 2500k
CM 212 Evo
Gtx 580
Corsair Hx 750
hp dvd1260
