Closed
Fraps won't work, GPU-Z crashes.
Just two days back everything was fine. I was taking screenshots with fraps. Then, i saw that the fps counter was not coming in dirt 2. However it was there in CoD:MW2. Then just recently the fps counter's disappeared altogether. Now i can't see it in any game whatsoever. I downloaded a trial od D3DGear. It works fine.
Another thing, around the same time this happened, gpu z also stopped working. It crashed every time i tried running it. I downloaded other versions and reinstalled/rolled back my drivers, nothing worked. GPU-Z keeps saying "an unrecoverable error has occured at 0x1EE0A7E". Everything else is pretty much working fine, all games running fine. Please help!
My config: xfx nForce 630i
2gb transcend ddr2 667
core2duo E7200 2.5ghz
xfx gts 250 1gb with 258.96 drivers.
Thank you.
More about : fraps work gpu crashes
Graphics card Authority
First things that come to mind are memory failure and virus. Check for memory failure the same way you would for a new build. A good way is Prime95, make sure "Detect Rounding Errors" is checked.
thanks, will do that. i somewhat had that in mind as i sometimes get blue screens, rarely. with prime95 how do iknow if my memory's faling?
Related ressources
Ask the community
