Is 550watts power supply compatible to athlon x2?
Hello,
may i know if 550watts power supply is compatible to athlon x2. seeking for help. thanks.
rgrds,
nel
2 answers Last reply
More about 550watts power supply compatible athlon
  1. Hello jenel;
    Athlon X2 and what else is in that system? In most cases a 550W PSU will be fine.
    It will be the whole system that decides what size PSU is a good match, most especially what video card you have installed.
  2. it has nothing to do with ur cpu, it should be compatible with the case that came with ur pc, what case do u currently have, most cases that are atx are compatible with most atx powersupply, also please list ur current ps model, to know if its a decent one
Power Supplies Compatibility Components
