clam101
5
my left speaker has suddenly stopped working when it is hooked up to my PC, but when I connect it to my iPod, or PS3, it works perfectly fine, I cannot figure out what is causing this. Any ideas?
Were you using the same cable to hook it into the computer and the ipod? I have had several speaker cables lose one channel after several years of use so i would check the cable, you might want to insert and remove the connector into the back of the computer a few times, just to make sure that the contacts arent dirty and blocking the channel.
