Problems:
When booting, my system crashes every time I try to load Windows normally, after the Windows loading bar. I am given a generic BSOD (update BIOS, update drivers, check video adapter, etc.). I am able to boot just fine in Safe Mode.
When attempting to reinstall XP using an Upgrade CD, the program is unable to detect the previously installed version of XP, and thus does not allow me to proceed.
New Rig:
CPU: AthlonII X4 925
Mainboard: Biostar A770E3
RAM: Wintec 2x2gb DDR3 1333
PSU: Thermaltake 600W
Old Rig:
CPU: Pentium E5200 2.5GHz
Mainboard: ASRock 4CoreDual SATA R2.0
RAM: GSkill 2x1gb DDR2
PSU: Thermaltake 430W
Both Rigs:
OS: Windows XP SP3
HDD: Seagate SATA 1TB 7200
DVD Drive
Attempts to Fix:
I have downloaded and installed the latest Motherboard drivers, from their website. I have flashed the latest BIOS, from the same. I have updated the drivers on my VC, from the Nvidia website.
Before the 2nd Problem cropped up, I was able to Repair my XP installation back to SP2. This did not fix the problem.
I am able to boot off of an Ubuntu LiveCD with no problems.
Note that when I switch my HDD back to my old rig, everything works as normal, using the same Windows install. When I boot off of the Upgrade CD, on my old rig, the CD detects the Windows install just fine. However, I should probably install Windows from my new rig, rather than my old one.
Any suggestions?
New Rig:
Old Rig:
Both Rigs:
OS: Windows XP SP3
DVD Drive
Attempts to Fix:
Any suggestions?
