Archived from groups: rec.photo.digital (More info?)
Hi
I have recently taken the 1st step towards color management - I bought
the Spyder2 package from Colorvision (not the Pro version) and had
tried several times to calibrate my Samsung SyncMaster 191T+ 19" LCD
screen.
Initially I got a significant color cast (yellow) after calibration
using default target "2.2-6500K". After reading Colorvision’s FAQ on
such problem, I repeated the same process using target "2.2-Native",
which reduced the color cast significantly, but not completely. I am
not sure why/what the new target is for.
The color cast is obvious, as at the end of the calibration process
the Spyder2 sw toggles a reference image BEFORE, then AFTER. The
BEFORE image would appear neutral, but the AFTER image has yellow
cast.
Has anyone experienced this before? What should I do next?
"colddude" <UseLinkToEmail@photoforumz.com> wrote in message news:41ee1342$1_5@alt.athenanews.com...
> Hi
> screen.
> using default target "2.2-6500K". After reading Colorvision's FAQ on
> cast.
If all you've ever used is 9300K, 6500K will look too yellow
at first. Give your eyes several days to adjust to the new setting.
A quick way to check is to put the monitor near a window with
sunlight coming in, and hold up a piece of white paper next to
the screen. 6500K should look about the same color, and
9300K (the "before" image) should look too blue.
>>Hi
>>screen.
>>cast.
Nother thing: the little test showing before and after is meaningless.
FWIW, on my third go with same equipment, I got it right, but I use a
gamma of 1.8. Double check to see that it's set for LCD calibration.
<MitchAlsup@aol.com> wrote in message
news:1106163425.196926.139930@f14g2000cwb.googlegroups.com...
> "If all you've ever used is 9300K, 6500K will look too yellow
> at first. Give your eyes several days to adjust to the new setting."
> I would have used the world "orange" rather than "yellow", but after a
> couple of days your eyes will adjust and all will apear normal.
Absolutely. You are just used to looking at 'electric blue' whites. It took me
more than a few days to get used to it, but I wouldn't have it any other way
now.
