Motherboard questiion help
im buying the msi p67a-g43 and the memory part say:
Memory
Number of Memory Slots
4×240pin
Memory Standard
DDR3 1066/1333/1600*/1866*/2133*(OC)
if i buy 1600 ddr3 memory will it work?
it say OC.
thanks in advance.
3 answers Last reply
More about motherboard questiion help
  1. That speed will work on your board. The reason for the * is because it's an overclock, OC, not a default speed. It won't work at that speed just by installing it. Meaning you will have to go into bios and set it at that speed.
    Ohs.thanks.
    I have one more question.
    If my gpu is 2.1x16 pcie n my motherboard say 2.0 will it work???
    Thanks in advance!!
  3. It will work fine. The 2.1 was the beginning of an instruction set for the 3.0 pci-e. There is no performance loss or gain between the 2.
Motherboards DDR3 Memory
