How many watts would be required to run a I7 930, HD5870, 6gb memory,1 optical drive, one hard drive 7200, and Cooler master Haf 932 with a couple extra fans? Please respond and if you have a suggestion for a psu post it.
The most important thing you need to consider is your video card. For one, how much amperage from the 12+v rail does it require and what is the minimum requirements of wattage you need for that video card. By looking at your specs you could go with a 650 watt. Make sure it's 80+ certified. Anything Corsair is great, i'm personnaly using the Corsair TX 750 watt - have been for about 3 years now(and it's still running strong) and i'm running a GTX 460 sli setup along with an i7 920. happy PSU hunting, cheers!
A quality 650W unit will run your set-up no problem.
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007657%2050001669&IsNodeId=1&bop=And&CompareItemList=58%7C17-371-021%5E17-371-021-TS%2C17-139-005%5E17-139-005-TS%2C17-139-012%5E17-139-012-TS%2C17-207-007%5E17-207-007-TS%2C17-207-002%5E17-207-002-TS
Will this be able to power my system? Which now consists of A cooler master 690 ii advanced, cosair liquid cooler for cpu, hd5870, i7 930, one optic drive, one 7200 rpm hd, 2 140mm fans, 2 120mm fans and a 80mm fan.
Sorry for the EXACT details but I just want to be sure.
