Solved
Cooler Master Extreme Power Plus 600
Can the Cooler Master Extreme Power Plus 600 W run the ATI HD Radeon 6870 which requires two 75W 6-pin PCI Express® power connectors. ??
Please help
Shubhankar
13 answers Last reply Best Answer
More about cooler master extreme power
  1. Yes, but if you do not own one, I'd suggest a better quality unit.
  2. Agreed with jsc. Extreme Power series from Cooler Master is their cheapest one, and not recommended for gaming rigs. Rather go with their GX series, Silent Power Pro or Silent Pro series. They are more expensive, but they are also better built and provide better efficiency than the Extreme Power series.
  3. I was asking whether the above mentioned PSU unit can run or not , simple. Wat about if I go for GX 550 ?? Reply Soon.
  4. Yes that psu will run that card but not very efficiently.And it's not a 600W unit it produces just shy of 550W.
    http://www.hardwaresecrets.com/article/Cooler-Master-eXtreme-Power-Plus-600-W-Power-Supply-Review/1034/9
    Cooler Master GX models aren't really much better and offer mediocre performance for the price.
    Here's a GX 650 review
    http://www.hardocp.com/article/2010/11/22/cooler_master_gx_650w_power_supply_review/1
    If you're looking for cheaper good quality units i would look for an OZC.
    Antec and Corsair make very good units but cost more.
  5. @Davcon : No very efficiently in the sense ?? Well I plan to run a system with 6 hdd internal and a 6870 Radeon ?? Which PSu I should go for. Suggest cheap and good budget is limited within 5k INR.
    http://www.theitdepot.com/details-Antec+EarthWatts+650W+Power+Supply+(EA650)_C14P3404.html
    http://techshop.in/store/corsair-cmpsu550vx-power-supply-buy-online-india-p-2930.html?cPath=320_194
    The Antec and the VX550 are really great units.
    http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=110
    http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=62
  7. Well the Graphics card mentioned above requires 2 * (6+2)pin 75 W power connetors. None of the above meintioned power supplies have such specification Can I go for Cooler Master M600 Silent Pro ??
  8. http://www.corsair.com/power-supplies/non-modular-psus/enthusiast-series-1/tx650w.html
    Will this Power Supply Unit do me good ?? Please Reply Soon.
    They certainly do!you'll only need two 6pin the 6+2 lead is for high-end cards.
    Both units have that as well.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
    http://www.corsair.com/power-supplies/non-modular-psus/enthusiast-series-1/vx550w.html
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
    http://www.antec.com/Believe_it/connectors.php?ProdID=27650
    The Corsair TX is also very good.
  10. So VX 550 will be enough for I think, Is that so?
  11. Cooler Master Silent Pro is overpriced IMHO. Antec HCG would do you well also. And you can then twist for a slightly more powerful PSU for the same price as the Silent Pro.
  12. Best answer
    Yes it would be fine!
  13. Best answer selected by shubhankar_venkatesh.
Power Supplies Cooler Master Power Components Product
