Approximate Purchase Date: tomorrow
Budget Range: Total system around $550
System Usage from Most to Least Important: playing back SD and HD video from my network hard drive over HDMI, browswing web from couch, youtube, hulu, boxee, etc.
Parts Not Required: keyboard, mouse, monitor, speakers, already own copy of Win 7
Preferred Website(s) for Parts: newegg
Country of Origin: USA
Parts Preferences: Intel i3 540 CPU, ASRock microATX H55M-Pro mobo, Seasonic or Corsair PSU
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: 1920x1080
Additional Comments: Must be silent, and as cheap as possible without sacrificing quality
First please excuse my inexperience, I'm building my very first PC and wish to make an HTPC. In my eagerness to get started I've ordered a few parts already but need advice on memory, hard drive, power supply and cooling. I purcahsed an Intel i3 540 processor with an ASRock H55M-Pro microATX mobo. I plan on running integrated graphics and sound over HDMI since I hear thats a strong point of the Clarkdale's. I also Bought an nmedia HTPC case, the 1000B model. I wish to run a "green" HDD, and don't plan on using a DVD/BR drive as they are quite noisy IMO.
This brings up the cooling concerns of mine. The case has two 60mm fan openings and one 90mm. I wish to make this as quiet as possible so I wondered approximately how many total CFMs I should require for intake/exhausting case heat?
Second is power supply. Using a few online calculators I come up with 200-230 watts. I found an efficient 300W Seasonic on newegg I like, would this be a good choice: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151086&cm_re=seasonic_300w-_-17-151-086-_-Product
Finally I need a HDD, around 300-500GB is plenty, and sytem memory. What do you suggest?
Overclocking: No
