Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Sound Cards > Highest Quality Way to Plug Speakers into my Sound Card?
Forum CPU & Components : Sound Cards Highest Quality Way to Plug Speakers into my Sound Card?
I have the Creative X-Fi HD sound card and I am going to purchase the Audio Engine 5's very soon. Which would be the highest quality way to connect them to the card?
http://www.tigerdirect.com/include [...] &imgcart=1
^ Picture of the sound cards jacks.
http://www.hometheaterhifi.com/vol [...] -panel.jpg
^ Picture of the speaker jacks
Thanks!
Message edited by whop1 on 03-04-2011 at 08:08:56 AM
Reply to whop1
I'd say use the RCA connectors, since RCA cables are usually better shielded than line-out cables. SPDIF would be even better, but you have no SPDIF-in on your speakers as far as i can see.
Unless that audio-in on the speakers is mini-SPDIF compatible, but the quality won't be as good as optical spdif anyway, since mini-SPDIF is usually coaxial
Optical SPDIF works over a Toslink cable and usually provides the best sound
Message edited by Vadim_79 on 03-04-2011 at 09:20:18 AM
Reply to Vadim_79
SPDIF is by far the best quality. But other than that, RCA's are king. Get the gold plated connectors with the shielded cable, and you'll be fine. Remember to get high-quality cable, as (as I like to believe), half of your system's quality relies directly on your cabling. Crappy cables = crappy interference = crappy signal = crappy amplification = crappy filters needed = crappy processed sound.
Paying up to half the amount as you did for your high-quality system just for cables really isn't an uncommon thing when it comes to audiophiles.
Just for the interest of it, I saw a B&W sound system the other day (just the drivers, no amplifiers or anything included) that sold for $11,000. When I asked why they were so expensive, I was informed that the calbing (literally just two 4m cables to connect the speakers to an amplifier) cost $2000. It was good cables though, every cable had two independently shielded cables inside them, one for the lower-mid bass and the other for treble. I was impressed...
Reply to Toxxyc
You have a very nice PC sound card. And the audio engine speakers are good too. Go to
www.audiogon.com and get a good used pair of RCA to RCA cables for hook up...
If you want to go the the "next level" you need to get digital out of the PC and convert it to analog in an external box (converter). Usually USB out of the PC. S/PDIF is more common in the audio world but is prone to some errors that degrade the sound. Then connect RCA's from that converter box to your speakers.
But that's expensive. Look up a USB DAC on audiogon under "CD-DAC". They start about $1000, used. Here's a nice one:
http://www.audiogon.com/cgi-bin/cl [...] -usb-black
Reply to jb6684
Analog > Digital, always, for the sole reason that sound does NOT digitize well.
Reply to gamerk316
my sound card has an audio in / out (headphone / microphone) then on the far left there are 2 larger ones that say opt in and opt out then on the right side there are 2 that say l and r. the opt in and out would be the highest quality to connect to correct?
Reply to whop1
Ok to make this easier go to their website and down load the set up guide.
It tells you exactly what you need and what goes where.
http://audioengineusa.com/Store/Audioengine-5#features
Message edited by galeener on 03-05-2011 at 01:54:10 AM
Reply to galeener
If your just posting to advertise don't bother as your going to be reported.
Reply to galeener
Two of the connections on the speaker go to the other speaker I would say go with a high quality RCA connection. gold plated . I know there are some out there that are gold plated but it will rub off if you use it about 10 times make sure you get high qulity ones.
If you need made to order monoprice.com has a lot of good stuff and is good quality.
Reply to galeener
Optical -out to optical-in over Toslink would be the best quality
That's how my FullHD media player is connected to the surround system. The sound provided over hdmi is worse IMHO.
Additionally my player can send the audio data in SPDIF RAW over optical, so DTS is not tampered with.
Message edited by Vadim_79 on 03-05-2011 at 11:15:40 AM
Reply to Vadim_79
OP, for what your looking at a simple 3.5mm stereo jack cable. That's basically a cable that looks like it's got a male headphone jack on each end. Unless you are laying the cable next to something like a fridge any old cable found dime a dozen at Home Depot or Radio Shack will do the trick. If you don't like the generic stuff head over to Monoprice.com and pick up a heavy one for a whopping $2.50.
Just plug one end of said cable into the "front" speaker jack on the sound card and the other end into you speakers and you're set. There are no other connection methods for these speakers.
Message edited by d0gr0ck on 03-05-2011 at 01:55:26 PM
Reply to d0gr0ck
After looking at the speakers again I noticed, that the RCA connectors found on them seem to be sub-out, instead of audio-in. So the only way to connect the speakers to your pc would actually be a 3.5 mm cable (it will also be of the least possible quality compared to RCA, coaxial or optical SPDIF)
Message edited by Vadim_79 on 03-05-2011 at 02:46:57 PM
Reply to Vadim_79
There are 1822 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
3930k idles low, boots hot, then cools?
By DJDeCiBeL, 3 hours ago:
Check your temps with HWMonitor, Core Temp or RealTemp. SpeedFan seems to be wrong more...
Best offers
Top experts
