Solved
[HELP] Looking for compatible RAM
Last response: in Memory
Best solution
Don't mix DIMM memory timings and voltages.
The F3-16000CL9D-4GBRH has an operating voltage of 1.65 Volts.
The F3-16000CL9D-8GBRM has an operating voltage of 1.55 Volts.
Mixing of RAM, especially DDR3 RAM often will not work or not work without issues even if of the same timings and voltage. It's always best to buy ONE matched, tested RAM Kit of the full quantity that you desire.
Related ressources
Ask the community
