Hello,
I built my friend a VERY budget PC just so he could play SC2 (he used to be addicted to sc1, and never had a PC since, and went ape**** when SC2 came out and he couldn't play it). Here are the specs
AMD Athlon II X3 440 Rana 3.0GHz Socket AM3 95W Triple-Core Desktop Processor ADX440WFGIBOX
Item #: N82E16819103843
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL4D-2GBPK
Item #: N82E16820231087
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
Item #: N82E16832116754
GIGABYTE GA-MA74GM-S2 AM3/AM2+/AM2 AMD 740G Micro ATX AMD Motherboard
Item #: N82E16813128342
SAPPHIRE 100293L Radeon HD 5570 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Low Profile Ready Video ...
Item #: N82E16814102874
Antec Basiq BP500U 500W Continuous Power ATX12V Version 2.01 Active PFC Power Supply
Item #: N82E16817371004
Seagate Barracuda 7200.12 ST3320418AS 320GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
His issue is that one day he went to turn it on and it would not even POST. It just beeped really loudly. He called me and I proceeded to play IT, trying to get him to zero in on the problem. Being as he has no extra components to try and troubleshoot, I asked him to open it up just to make sure that everything was still plugged in and nice and snug. When he turned it on its side, and then checked everything (nothing was loose). He hit the power button and it booted just fine. With seemingly nothing done to it besides turning it on its side, it booted up fine. Two days later and it is dead again, with the beeping again. I am guessing it is a hard drive failure; any thoughts? Can hard drives fail for a little and then work for a little as described above? Is there any chance (if it is the HDD) that he would possibly be able to save his data? Any opinions on what could be the culprit if it is NOT the hdd?
Thanks in advance for any assistance.
