Most power for my buck
So I have a budget of around $300 - $400 for CPU + MoBo.
I want the most processing power I can get. I'll mostly be multitasking, No gaming. If anything big, some 3D modeling.
Anyways can I get some advice on the CPU MoBo Combo?
Options so far.... (i'm open to other suggestions)
Phenom II X6 1090T
Phenom II X6 1055T
Phenom II X4 840
Phenom II X4 955 BE
Phenom II X4 970 BE
ASUS M4A88TD-V EVO
ASUS M4A79XTD EVO
ASRock M3A770DE
GIGABYTE GA-790XT AMD 790X
i5 2500
i5 2500K
i7 - 2600
i7 - 2600k
P67 or H67
14 answers Last reply
More about most power buck
  1. This is hard to answer! If it was just a performance question it would be easy!
    Here is 2500K compared to 1090T http://www.anandtech.com/bench/Product/146?vs=288
    2500K compared to 2600K http://www.anandtech.com/bench/Product/288?vs=287
    No question the performance goes to the Intel CPU's
    Which chipset is going to be based on are you getting a K CPU for overclocking, are you going to be using the built in HD graphics?
    Building a X6 1090T system would though be cheaper and the only board that you list that I would buy today is the M488TD-V EVO since it has USB3 and SATA6GB.
    Fail :lol:
    (sorry -- I'm tired of Anand's craptastic benching and nVidia/Intel fanboy hype & headlines :D )
    A hex-core 1090T with an ASRock 890GM Pro3 R2.0. If yah don't like that one, wait a few weeks for another 'black-socket' motherboard from another OEM.
    edit --- sorry, forgot this:
  3. Wisecracker said:
    Fail :lol:
    http://media.bestofmicro.com/5/C/274944/original/3ds%20Max%202010.png
    So obviously the I7 2600K is better than 1100T!
    (typed on AMD based computer)
    I think the SBs are great -- it's a shame I'll never be able to afford one (new, anyway - LOL).
    It's interesting that the 1100T (being all of 100MHz faster that the 1090TBE) runs with the i-2500k & i-2600k. 3D modeling is simply where AMD and Intel are highly competitive. The $190 price point wins my dollar (that is -- if I had any!).
    I understand the new SBs are great over-clockers, but the EO 'BE' Thubans ain't no slackers in that department, either. And if the OP finds himself a 'black socket' motherboard (in the next month or so [:jaydeejohn:5] ) he should have a really nice upgrade path.
  5. That is exactly the reason I said it is a difficult question to answer since OP asked for performance/price. 1100T + 880td-evo $330 after MIR http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.613790
    I7 2600 $299 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115071
    MSI H67 mATX board $100 http://www.newegg.com/Product/Product.aspx?Item=N82E16813130569
  6. would I be making any kind of mistake if I went with the i5 2500K and a "black socket" MoBO?
    Also how much is that MoBo going to cost? and why are they so hard to find?
    He is referring to an AMD board with the socket.
    There is nothing wrong with going with a 2500K and a P67 or H67 board, I would prefer P67 with the K CPU.
  8. Ok it seems really hard to find a good p67 in stock right now. I like gigabyte and all their board are tough to get a hold of. Am i just being blind?
  9. You are not blind the boards, with revised chipset, are rolling into retail now after their recall. There will be more options next week than there is now (the ones there only showed up this week)
  10. Ok cool so here's what i'm looking at
    Processor: i5 2500K
    Mother Board: MSI P67A-GD65 (B3) LGA 1155
    Ram: G.SKILL 4GB DDR3 1333
    Power Supply: Cooler Master 500W
    Case: Cooler Master HAF 912
    DVD Drive: ASUS Black 24X
    HDD: Samsung 1TB 7200
    SSD: OCZ Vertex 2 80GB
    I don't care about my GPU right now, i'll figure that out later.
    Any suggestions on what you see here?
  11. I would stay away from Cooler Master PSU's since they are hit and miss in quality. Look for brand names like Antec, Corsair, Seasonic and Enermax for the 500 watt size range.
  12. ok great thanks for the help!
  13. The newegg combo for the Asus P8P67 pro and i5-2500k was $390
    RAM - $40 is better than $50
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820145260
    Case - Tho I often recommend and build w/ the 922, the 912 just doesn't cut it. The 300 is a better case / deal.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
    Cooler Master PSU's are not a direction I'd go. Best buy right now are the XFX models . Huge rebates make them more attractive that lower wattage models:
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=XFX+650&x=0&y=0
    The Vertex 2 doesn't come in an 80 GB, grab the 90 if ya not gonna wait till Vertex 3's. The 120 GB ones have capacity issues.
    And when ya get to the PSU, start looking w/ the 560 Ti's
    $240 - ASUS GeForce GTX 560 Ti w/ Free JC2 + Mafia II coupon
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814121424
    http://www.overclockersclub.com/reviews/nvidia_asus_gtx560ti/17.htm
    Quote:
    The performance was good right out of the box with both of these cards and when it came time to overclock them, I was able to hit over 1GHz on the GF114 cores of both cards and well over 1150MHz on the GDDR5 memory. These bumps in performance from overclocking were not just small bumps, but significant jumps in performance, allowing the GTX 560 Ti from NVIDIA and ASUS to wipe the floor with the HD 6870, its direct competitor. Either AMD has some price drops coming soon or it will be conceding the $250 price point to the performance of the GTX 560 Ti.
CPUs Power Phenom Product
