Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Motherboards > Question about Audio Controller
Forum Motherboards & Memory : Motherboards Question about Audio Controller
Greetings,
This is more a question about the motherboard audio codec than anything else, so I'm putting it here.
I'm using a Logitech S-220 speaker set (3.5mm) which is plugged in the motherboard I/O and a MXL Studio 1 Microphone (USB) which is plugged into the front panel I/O. I'm also using a Logitech QuickCam Pro 9000 webcam with microphone which could potentially be part of the issue as well. The motherboard is a GIGABYTE GA-880GA-UD3H which has a Realtek ALC892 7.1 audio controller.
Here are links to the items in anyone needs more info:
Speakers: http://www.newegg.com/Product/Prod [...] 6836121014
Microphone: http://www.newegg.com/Product/Prod [...] 6836709013
Webcam: http://www.newegg.com/Product/Prod [...] 6826104074
Motherboard: http://www.newegg.com/Product/Prod [...] 6813128444
Whenever I plug in the microphone, the speakers stop working. They come back automatically when the microphone is removed. I'd like to find the reason for this and find a way that I can have both items running at the same time.
My only thought thus far is that my microphone is somehow confusing the integrated audio controller and comes across as a speak connection, nulling the other speakers.
If this is the case, I suppose I'd have to buy a discrete sound card to run my speakers, so that they wouldn't conflict. I'd rather not have to buy anything else though.
Thanks
Reply to timagrover
If you plug the microphone in, and go to the sound settings in Control Panel, what is selected as the output device? Can you change it to the Realtek output?
Reply to itzdanielp
There are 1851 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Do I need a new motherboard?
By smorizio, 3 hours ago:
you waste your money unless you where getting an overclock cpu. any new mb with the same...
Best offers
Top experts
