Hi all,
I just got a new XFX 9800 GT card and a new monitor Acer H203H. When I power On, the monitor shows no signal.. all cables are properly connected though..
my XFX 9800GT has a DVI-I Dual link output and the monitor has a DVI-D port(and also a VGA).. the cable I am using is a DVI-D single link cable. Do I need to get any adapter for this..
I also tried connecting the VGA pin to the gfx card using a VGA to DVI-I dual link adapter.. even that results in the same..
Any ideas what I am doing wrong..
Thanks!!
Thanks!!
